thejdm.com v3
the original tjdm.
Skip to content
Spnfedeg6 build FINALLY completed!! PICS INSIDE!!
Postby spnfedeg6 » June 26, 2010
Well I never started a build thread or anything like that but here is what Ive been building for the past eight years. LMK what you guys think.
1992 Civic Si / 178,000 miles
Engine/Tucked/Bay mods:
-Engine: B18c Jdm block, GSR rods, GSR crank shaft, arp rod bolts, fully balanced and blueprinted bottom end
-JDM GSR LSD transmission
-Exedy Lightweight flywheel and Stage1 clutch
-Spoon Sports P72 ITR pistons .25 overbore
-Spoon Sports high tension ground plug wires
-Spoon Sports carbon kevlar plug wire cover
- Mugen baffle oil pan
-B16A PR3 head, fully ported and polished
-Bronzed valve guides
-Skunk2 stage 2 cams
-Skunk2 adjustable cam gears
-Skunk2 high compression valves
-Portflow titanium retainers and valve springs
-Skunk2 intake manifold powder coated silver
-Hondata intake heat shield gasket
-Edelbrock 65mm TB
-Greddy timing belt, ITR water pump and oil pump
-Chasebays tucked fuel lines
-RC engineering 310cc injectors
-AEM black fuel rail w/ black pressure regulator and Marshall liquid filled fuel press gauge
-Walbro 255 fuel pump
-Mugen 4-1 header
- Omni power 2.5” test pipe
-T1R B-Pipe
-Mugen twin loop muffler
-AEM Hybrid cold air intake
-Shaved valve cover powder coated
-Hasport polished motor mounts/ deleted A/C bracket and trans brackets
-Blackworks Racing rad hoses
-Fluidyne polished dual core radiator
-Mugen thermostat and thermo switch
-Spoon Sports plug wires w/ S2K platinum plugs
-Engine management is Hondata S200
-Vision hood dampers
-Boltboys/DownstarInc. Stainless bolt kit
-Rywire Mil Spec Harness w/ labels
-Tucked headlight harnesses
-Chasebays Brake Booster delete w/ Wilwood master cylinder
-Chasebays Brakeline tuck flex lines
-Chasebays black tucked clutch line
-Chasebays ground kit
-Custom welded/shaved/smoothed engine bay with no seams
Exterior/Body:
-JDM EG6 headlights
-JDM Vision corner lights (smoked)
-JDM EG6 taillights
-JDM EG6 Stanley yellow fog lights
-JDM EG6 thin side moldings
-JDM EG6 Bronze glass all window except windshied
-JDM EG6 Door visors
-JDM EG6 mud guards
-JDM EG6 side markers
-JDM EG6 Civic SIR-S badging
-JDM EG6 hood nose bra
-New wiper cowl and molding
-New OEM windshield
-New Front and Rear bumpers
-All New exterior moldings/side skirts replaced with OEM parts
-Mugen front lip spoiler
-Mugen plate bolts
-Vision carbon fiber mirrors
-Spoon sports duckbill spoiler
-Full paint job by Dave at Hableib Auto Body
Suspension/Brake:
-Function Form type2 coilovers
-Spoon Sports Fr. upper strut brace
-Spoon Sports R. upper strut brace
-Skunk2 front upper camber arms powder coated Black w/ new version ball joints
-Hardrace roll center adjusters
-Hardrace front lower control arm bushings
-Suspension Techniques front and rear sway bars
-Skunk2 rear camber arms
-Spc rear heim joint toe adjusters
-Prothane trailing arm bushings
-Function7 rear lower control arms
-ASR sub frame brace
-Front upper sub frame brace off ITR
-All suspension components in front powder coated wet black
-All rear suspension components in rear powder coated fine textured black
-Manual steering rack conversion from a Del Sol
-New OEM wheel bearings Front and Rear
-Blackworks Racing extended wheel studs and lug nuts
-GSR front brake upgrade
-Powerstop rotors front and rear
-Powerstop race brake pads front and rear
-Powdercoated calipers front and rear (Gold)
-Goodridge stainless braided brake lines
Wheels/Tires:
Mugen MF10L 15x7 +40 offset wrapped in Bridstone Potenza tires 205/50/15
Interior:
-USDM ITR front seats
-JDM EG6 climate control
-JDM EG6 clock
-JDM EG6 foglight switch
-JDM EG6 defrost switch
-OEM optional center console
-OEM floor mats
-OEM optional rear speakers and grille kit
-ITR shift boot
-Mugen pedals
-Mugen shift knob
-Alpine cd player with I pod attachment
-Alpine speakers front and rear
-Rear seat delete kit
-Battery relocation under rear seat delete/Odyssey battery and bracket
-15” full size spare tire under rear seat delete
-Both front seat belts replaced with brand new Honda belts
spnfedeg6
65% ricer
Re: Spnfedeg6 build FINALLY completed!! PICS INSIDE!!
Postby ap_red97ek » June 26, 2010
saw this car in person tonight. very nice :thumbup:
ap_red97ek
1997 Honda Civic
Highscores: 8
Cool man where did you see it at?
spnfedeg6
65% ricer
Postby Wax_Hands » June 27, 2010
Very clean, nice work. This car has Wax_Hands approval...that means a lot too! :p
Wax_Hands
Highscores: 1
Postby tenchu » June 27, 2010
holy fucking firewall!! nice!!
1993 Subaru Impreza
Postby spnfedeg6 » June 27, 2010
thanks alot guys!!
spnfedeg6
65% ricer
Postby Jams_ek » June 27, 2010
nice bro the bay looks amazing!!!
Jams_ek
2000 Honda Civic
Jams_ek wrote:nice bro the bay looks amazing!!!
thanks again!
spnfedeg6
65% ricer
Postby ap_red97ek » June 27, 2010
spnfedeg6 wrote:Cool man where did you see it at?
I saw it in irwin at the car cruise. I checked it out while i was there. I drove by when i was leaving, i was in the blue WRX
ap_red97ek
1997 Honda Civic
Highscores: 8
Postby .saint » June 27, 2010
so incredibly clean. jaw dropping steve! car looks incredible!
so how are the brakes since the booster delete?
[.saint works] is coming soon!
.saint, the rolling honda EK parts jdMuseum.
mac miller straight up kills it! poop.hell sideways.brigade
http://www.builtmotorsportswear.com
http://www.frightmarestudios.com
1999 Honda Civic
Highscores: 5
Next
Return to eg & del sol
Who is online
Users browsing this forum: No registered users and 1 guest
cron
