Hey guys, I just traded my 97 4 door for a friends 92 cx b20z turbo hatch.. I think I got the short end of the deal. The car shuts off at 5K rpms and seems to be pushing only 2 lbs of boost. What the car has b20z motor, si trans, off brand turbo, pr4 ecu (needs hondata installed), msd with launch control, a/f guage not hooked up, boost guage, turbonetics waste gate, hks bov, fmi, greddy turbo timer, fuel pres reg, fuel rail, venom 320 injectors, 4 wheel disc brakes and teg interior.
I know nothing when it comes to boost. I do know I need to run new vacuum lines to fix the hack job he did, I need to re-do oil lines b/c of a leak at the pan. It has an exhaust leak where the manifold and turbo meet, it seems as if the gasket blew out. The waste gate was only hooked up at the vac port, the boost port was not hooked up to any vacuum lines, or does this need connected to port on turbo compressor?
Any suggestions on what to do or where I can find more info will be greatly appreciated. I've checked out a lot of Honda-tech topics but its like reading Greek. I almost feel as if I would be better off putting new oil pan on it and throw a stock header on and run it that way.. I've always wanted a boosted car and now I have it and I'm more depressed at the work it needs.. But lemme know what you guys think.. thanks!!
