well not making power under 3500 is no biggie when i launch from full throttle lol, if i hold idle at anything less then 3000 rpms itll bounce a few rpms, kinda sounds like a stutter box. ill make a vid with my friends phone and post it up. i would have changed the mani but Y7 are soo different not sure it would work.. when i go to the junk yard im also going to get a regular throttle cable to test out the Z6 maniNatural Aspirations wrote:The y7 engine uses 190cc injectors. Its running lean, if that is the case because the ECU thinks it has 240cc injectors that the Integra would have.
My point this whole time is unless this car has a manifold swap and uses the common 2 wire IACV it will not idle or run past 3500 RPM. Another sensor that is different between the motors id the CFS another check engine light would be found with this.
I call B.S.
D Series with Ls brains.. LOL
Natural Aspirations
- 55% ricer
Natural Aspirations
- 55% ricer
2.SloEK wrote:well not making power under 3500 is no biggie when i launch from full throttle lol, if i hold idle at anything less then 3000 rpms itll bounce a few rpms, kinda sounds like a stutter box. ill make a vid with my friends phone and post it up. i would have changed the mani but Y7 are soo different not sure it would work.. when i go to the junk yard im also going to get a regular throttle cable to test out the Z6 mani
What year is your engine/car?
Natural Aspirations
- 55% ricer
Natural Aspirations
- 55% ricer
Natural Aspirations
- 55% ricer
