What 2 Do Next?
Post by Sean @ NDF » March 02, 2005
horror wrote:My suggestion BOOST!!!
:idea:
Post by munster » March 02, 2005
a double decker wing and NAWS!
Do suspension stuff. Sway bars, strut bars, control arms, etc. At least it'll handle well if it isn't fast.
JaySmith
30% JDM
Post by JaySmith » March 02, 2005
Well I already have the following for suspension.
Tein Type SS Dampers
Alex C Pillar
Alex Trunk Bar
Spoon Front Lower Tie Bar
Spoon Rear Lower Tie Bar
However the Spoon Tie Bars are being removed, as the Fronts really messed up. haha And I purchased the Beaks Subframe Tie Bar to replace the Rear. And I also just purchased SRR LCAs not to long ago, so there awaiting to be put on. And I won't be doing a Sway Bar, unless its from the SiR (which is a possibility), as I don't want to risk subframe damage with these soft spring rates.
I just E-Mailed Kings, and AJR about the Mugen, and Spoon suspension. Can't go wrong with Showa. :P
Parker
Post by Parker » March 02, 2005
Honda sticker looks good. I've got mine at a crazy angle on the top left hand side (from inside the car). Oh yeah, thats the passenger side for me, RHD Biatch!!! :P
2000 Civic Jordan EK4
Jdmy0.com
Game Over - Dream, Build, Drive!
Post by hondalowlow » March 02, 2005
boost. it
maby get a nice manifold and get a junkyard turbo and rebuild it then make a down pipe then get IC pipe bent then all u gotta spend $ on is the manifold turbo ic and bov.. everyhtign elese is cheap..
Post by .saint » March 02, 2005
if u want a good sway/tie combo check out asr. the tie bar is actually a full sheet of steel that covers the subframe reducing stress and wont rip.
Mugen Ferio
Post by Mugen Ferio » March 03, 2005
you could get a b16a motor for about 2500 shipped depending on where you go? but like munster said, do suspension, although you seem to have a pretty decent set up. and anything Mugen is great! hint hint.....good luck with the car
/// MUGEN 無限 Equipped :thumbup:
four.FUNCTION :beer:
JaySmith
30% JDM
Post by JaySmith » March 03, 2005
B16A in my opinion just wouldn't cut it. I wouldn't be happy in spending money on something so weak. I would probably choose to go B18B before I went with the B16A. :) My suspension setup is meh, I'd prefer it to be better. :D And I would like rear disc too, if I could only find it.
JaySmith
30% JDM
Post by JaySmith » March 05, 2005
So here's the run down, as I've finally decided on what I'm going to be doing. :)
Alex Front Strut Bar - $240.00
Alex Rear Strut Bar - $210.00
Do Luck Rear Cross Bar - $432.00
Honda Civic SiR Rear Sway Bar - $242.35
Tein Type SS Replacement Springs (10K/6K) - $247.00
TOTAL: $1371.35
Additional Possibilities...
Falken Azenis Sports - $550.00
PasswordJDM Power Mirrior Harness, and JDM Switch - $150.00 usd
All prices were converted to Canadian currency, except for the wiring harness. haha And if I can find a set of used right, and left front lower control arms, and shock forks from a 99-00 Honda Civic Si/SiR I'll be doing the front SiR Sway Bar as well. :D Hopefully this will keep me happy in the handling department for quite sometime. And whatever money I have left over (hoping lots), I plan to save for a road trip this summer. :D
[EDIT]: By the way, does anyone have pictures, or some sort of instructions on where to cut the holes for the Rear Strut Bar? Its stupid there's no precut holes. haha
EK@FL
Post by EK@FL » March 06, 2005
Hey, James fastbrakes.com makes a drum to disc conversion, http://www.fastbrakes.com/products/prod ... =EF-EKrear
And I think AEM also makes a conversion kit.
