vitara pistons
idreamidrive
vitara pistons
Post by idreamidrive » June 23, 2009
how fucked up would my sohc run if i ran vitara pistons in my engine before going turbo. i need to pass emissions next month and i am trying to get my engine built before then but also maybe want to go turbo.
its just up in the air right now. stupid rod knock.
Signature
Zero
Re: vitara pistons
Post by Zero » June 23, 2009
well your compression is going to drop significantly but if you tune it right i dont see why it wouldnt run right.
Re: vitara pistons
Post by boostjunkie95 » June 23, 2009
You would lose a little power because of the lower compression, thats about it, it would run perfectly fine otherwise. Vitara's compression ratio is 8.5:1, stock pistons are around 9.2:1 i believe, not that huge of a gap. You could always have a few thousands milled off of your head to compensate if your that worried about it.
Re: vitara pistons
Post by Sean @ NDF » June 24, 2009
You will throw a cel. Probably triggered by o2 sensor
jdm delivery
Re: vitara pistons
Post by jdm delivery » June 24, 2009
why havent you killed yourself yet? lolololol j/k long time no post!
idreamidrive
Re: vitara pistons
Post by idreamidrive » June 24, 2009
Sean @ NDF wrote:You will throw a cel. Probably triggered by o2 sensor
will throw one or probably? i dont understand emissions and internal shit
Re: vitara pistons
Post by Sean @ NDF » June 25, 2009
Incorrect fuel burn. However, I passed with mine. I just unplugged my ecu right before he tested it so the cel went away temporarily.
Re: vitara pistons
Post by .saint » June 25, 2009
pull the cel bulb.
Re: vitara pistons
Post by Sean @ NDF » June 27, 2009
In Cali, they plug the machine right into the computer. pulling light bulbs doesn't work. the cel will show up anyway
Re: vitara pistons
Post by .saint » June 27, 2009
ah, bummer.
