Ringing Noise
akhlaq768
Ringing Noise
Post by akhlaq768 » October 09, 2005
Apart from the first gear, I can hear an annoying ringing noise when the rev meter is between 2 and 2.5 rpm
It starts straight away when it hits 2 rpm clearly can be heard until 2.5 rpm
What can it be?
Post by Sean @ NDF » October 10, 2005
mods? car? mileage?
Post by munster » October 10, 2005
Could be something as simple as a loose heat shield.
akhlaq768
Post by akhlaq768 » October 11, 2005
banzai wrote:mods? car? mileage?
Its a Honda Civic Coupe 1.6 lsi 1997 - D16Y7
The car is totally stock, current mileage is 85K
Post by munster » October 11, 2005
Check the headshields near the oil pan and the one under the front seats.
akhlaq768
One thing I noticed today was as the noise appeared at 2 rpms - I slightly decreased the accelarator and then applied it again, The noise disappeared straight away
I had my heatshield up front come loose and it did the same thing. At 3k it buzzed then stopped a little above 3k. Annoying as hell.
That's why I'm saying that's what it is.
akhlaq768
Post by akhlaq768 » October 12, 2005
munster wrote:I had my heatshield up front come loose and it did the same thing. At 3k it buzzed then stopped a little above 3k. Annoying as hell.
Thanks alot mate - will give it a go
Post by munster » October 12, 2005
Let me know how you make out.
PoorBoY
80% ricer
Re: Ringing Noise
Post by PoorBoY » October 12, 2005
akhlaq768 wrote:Apart from the first gear, I can hear an annoying ringing noise when the rev meter is between 2 and 2.5 rpm
What can it be?
Rev meter? 2-2.5 rpm? wow...
I AM LOOKING FOR SOME ONE WHO CAN PHOTO SHOP ME A SIG(I'm looking at you Josh!)
