Hood latch
fourth generation civic & crx tech. [84-91]
Moderator: Nikku
kyle
Post by kyle » January 10, 2004
^^running it through the engine bay is a good security measure. where it does meet the front t support you should fab up some kind of shield so people can't reach in there and pop your hood and rob you stuff.
i miss my hondas.
Post by Nikku » January 10, 2004
kyle wrote:^^running it through the engine bay is a good security measure. where it does meet the front t support you should fab up some kind of shield so people can't reach in there and pop your hood and rob you stuff.
true, a shield or razor blades 8)
Post by Nikku » January 11, 2004
ok here are the pictures
Image that is the grommet in the engine bay, right next to the brake booster
Image a better shot of the area you have to work with
Image inside the car, its up and slightly left of the clutch pedal
Image how i have the cable running for now, it interfears with nothing, when i change the carpet i am going to run it under the carpet for even less of a chance of it interfearing with anything
Image it runs above the intake manifold
Image snakes over the battery
Image best sticker on my car EVAR
and thats all for my pix, when i do my reswap i will run the line alot better, but for now it does the trick
Post by kotomile » January 11, 2004
Thanks for the pics, temp!
I'll definately give that a try, but I'll run it through a little more hidden-like. When you re-swap, how are you going to run the cable through defferently?
kotomile wrote:Thanks for the pics, temp!
not sure just yet, i will look at it when the motor is out to try to figure out a good way to run it so that its hidden
phan
40% JDM
Post by phan » January 11, 2004
temp wrote: Image best sticker on my car EVAR
you = bastard! :)
Post by Nikku » January 12, 2004
you = bastard! :)
hehehe
