knocking?!?
redex94
knocking?!?
Post by redex94 » August 16, 2004
When I start my engine and hit the gas whether in nuetral or in gear, it starts to Knock a little, I think it may be a vavlve spring, but it goes away after about 3minutes or until the motor is warm. Only does this if the motor is cold. :shock:
Life is but a dream, so go to sleep
Post by kotomile » August 16, 2004
is it a knock or a clicking sound? It sounds like your valves are out of adjustment.
urbanracer2000
90% ricer
Post by urbanracer2000 » August 16, 2004
Don't worry about it, Just go to honda and get a valve adjustment done. $120. Problem solved, please just pay a honda tech and not some bullshit garage to do it.
redex94
Post by redex94 » August 17, 2004
Ok thanks it is liek a knock only coming from under the valve cover, doesnt sound like the pistons, I ll call the honda servise dept. later thanks
urbanracer2000
90% ricer
Post by urbanracer2000 » August 17, 2004
No problem, I had the same shit happen. It would only knock a bit on cold starts, you know first thing in the morning type stuff. I was always paranoid anyway with the DOHC chatter, so that ended that worry too.
