Pulling my motor to replace w/ oversized pistons
Re: Pulling my motor to replace w/ oversized pistons
Post by boostjunkie95 » November 02, 2010
If you're getting the crank or rod journals machined make sure you plastigage them to make sure your clearances are in spec before you do your final assembly. Sometimes machine shops can get sloppy/lazy. Just make sure everything is supa dupa clean!
