Tranny problems
Post by BRYCE » June 14, 2004
huh whats that mean?? and yes i feed my civic 20 bucks worth of gas today! ARGGH
Post by Nikku » June 14, 2004
jay99ek wrote:wow.. dumping a 6-puck at 6000rpms..
you can damage the pressure plate..
you can damage the gears.. but more importantly the mainshaft..
the driveshaft can become tweaked or break under pressure..
motor mounts can wear fast..
if you keep doing it.. eventually.. if nothing goes before then..you could throw a piston/rod through your block..
more wear goes towards cv boots and axles..
torque converter will definitely warp or break if you keep dumping the clutch at 6000rpm at a full stop..
if you haven't broken your clutch in properly.. you'll break your glaze your clutch faster than anything else.. and it'll end up no good..
if you're going to be launching at that high of rpm.. i suggest you upgrade your motor mounts and start doing rolling launches..
get your car rolling forward at about 5-10mph.. then dump the clutch..
ahem NO TORQUE CONVERTOR ON A STICKSHIFT
Post by BRYCE » June 15, 2004
Good that you found the prob!
