tomoyasu
Post
by tomoyasu » February 16, 2008
word^
we tried push starting again. didnt work , can hear the fuel pump though..
my dad thinks the engine may have seized..lets hope not
Post
by Nikku » February 16, 2008
check the main relay!!!!!!! thats a main main main problem on the EFs that causes a no start on an otherwise perfect engine. also, are you throwing any codes from your ECU?
tomoyasu
Post
i will now that i saw the pic u posted. i read somewhere that it caused the fuel pump not to work though, and mine works.
Post
by Nikku » February 17, 2008
it can cause it not to work, but its one thing you def need to check. what about codes? are you throwing any?
Teaks92HB
- 45% ricer
Post
by Teaks92HB » February 18, 2008
main relay cuts power to injectors and ecu.. good one to hook up kill switch to.. i m o . good luck buddy
tomoyasu
Post
by tomoyasu » February 19, 2008
word. im gonna check some stuff out tomorrow, call my bank and see if they can do anything for me money wise so i can get this thing back on the road.
tomoyasu
Post
by tomoyasu » February 20, 2008
well its not throwing any codes as far as i can tell. and, not seized because i can turn it over by hand.
gonna check the main relay tomorrow.
called my bank too and the only thing they can do for me is a credit card
tomoyasu
Post
checked the main relay, everything looks good there. gonna try bump starting again here in a lil
Teaks92HB
- 45% ricer
Post
by Teaks92HB » February 20, 2008
i had a similar problem when my starter took a shit.. my battery was so low that i couldnt even push start it. you may wanna check batt also.
tomoyasu
Post
by tomoyasu » February 21, 2008
just got the battery replaced a couple of weeks ago.
