cars not workin
Teaks92HB
Post by Teaks92HB » April 08, 2008
even no fuel or spark it should still crank right? it doesnt turn over..
93ludeSi
Post by 93ludeSi » April 11, 2008
if it doesnt turn over at all it has to be electrical from the sounds of things, especially if he cant jump start it. without fuel or spark you would stil be able to crank the engine over. you ever get ahold of another ecu to try? also pull your ecu out and check it out just to see if any noticable things are wrong (blown capacitors ect.) Most other things i can think of should be able to be by passed by jump starting the car...
93 Prelude Si H23 VTEC
tomoyasu
Post by tomoyasu » April 18, 2008
just decided to say fuck it and took it too a shop yesterday.
tomoyasu
Post by tomoyasu » April 24, 2008
called the shop today and they said that they finally found a starter that fit it. now they're saying it has a short somewhere and that they would try to fix it today or tomorrow.
tomoyasu
Post by tomoyasu » April 29, 2008
they got it cranking good now. one of the cylinders was completely flooded..hopefully not too long before i feel the vtec goodness once again
Teaks92HB
Post by Teaks92HB » May 17, 2008
?? update
tomoyasu
Post by tomoyasu » September 15, 2008
well it was running good up until a couple days ago. the battery light started coming on. it was solid but is now flickering and only at idle(idle shows on the tach as 0 rpms). if i press on the throttle at all the battery light starts to dim and is completely gone at around 500 RPMs. the battery also seems to be getting drained while the car is off.
Teaks92HB
Post by Teaks92HB » September 15, 2008
check all connections to battery and alternator.
tomoyasu
Post by tomoyasu » September 16, 2008
for shizzle
