Low idle
Low idle
Post by munster » June 23, 2003
My car idles around 500-600rpm when warmed up. I changed the plugs and wires. Adjusted the slack out of the throttle cable. and it still does it. Any ideas what it could be? It doesn't stall or anything, but holy shit is it annoying.
spun vtec
Re: Low idle
Post by spun vtec » June 30, 2003
munsterEK wrote:My car idles around 500-600rpm when warmed up. I changed the plugs and wires. Adjusted the slack out of the throttle cable. and it still does it. Any ideas what it could be? It doesn't stall or anything, but holy shit is it annoying.
try the idle adjustment screw on the throttle body it takes a flat head screwdriver. play with it wile the car is on and idleing and i bet that will do the trick
.:sohc ownz:. > ///M pwr..
Turbogixxer
Post by Turbogixxer » August 07, 2003
Did it always idle that low or after you did something to your car?
jay99ek
Post by jay99ek » October 01, 2003
reset your ECU..
unplug positive cable.. then negative cable.. let your car sit with both cables away from the terminals on the batteries for a couple minutes.. then reconnect it.. turn off AC/put climate temp to hot/turn climate fan off/turn radio off/everything inside the car that uses up power off.. then start the car.. do NOT blip or give throttle.. let your car sit on LEVEL land.. for about 10 minutes.. then shut off your car and your car should re-calibrate itself back to normal..
AIM: MugenEKJay
e-mail: [email protected]
witeboi
Post by witeboi » November 25, 2003
jay99ek wrote:reset your ECU..
dayum dude you don't have to do all that... just disconnect the negative on the battery for like a min or two and it should reset... all i ever do never had any probs.. lates :2: :P
nonJDMdsm
60% ricer
Post by nonJDMdsm » November 25, 2003
x 2
