b18b head on b20 block
popeye
Post by popeye » April 19, 2004
I have a B20b in my 89 CRX. I am converting it to obd1 running the b18b obd1 ecu.I dont have the money for vtec so i was wandering if i put a b18b head on the b20 block if it would raze the compression and would be able to rev to 7200 on the stock bottom end
Re: b18b head on b20 block
Post by Nikku » April 26, 2004
b20rex wrote:I have a B20b in my 89 CRX. I am converting it to obd1 running the b18b obd1 ecu.I dont have the money for vtec so i was wandering if i put a b18b head on the b20 block if it would raze the compression and would be able to rev to 7200 on the stock bottom end
it would not raise the compression, however the B18B head flows better then the B20 head and would have better flow (obviously) at the higher RPM speeds
r_senik
Post by r_senik » October 24, 2004
are you planning to boost? with your swap youll get more power if your boosting.the ls head will do you good.
92 eh2
C.R.X
Post by C.R.X » December 13, 2004
just a thought; those b20 are infamous for their thin bearings. I recommend you upgrade them soon. or if not, just don't run it over 6krpm.
Punkracer
Post by Punkracer » January 19, 2005
[quote="C.R.X"]just a thought]
i agree upgradeing the bearings and i recomend ARP rod studs too, from experance with b20 / b18a/b i say use ACL bearings . all the crank and rod journals on the crank are the same the GSR and B16 bearings are a lil looser than the LS/b20. they're still with in spec @ about .025 on the platigage but the GSR/B16 will allow better oil flow within the bearing surface cause less wear and higher reliablity than a stock ls bearing.
you can get the bearings @http://www.kteller.com or http://camp1320.com/main.html
good luck in your build :up:
A.D.D. Motorsports
>ENGINE SWAPS
>TURBO INSTALL
>ENIGNE BUILDS
*Complete Swap's starting at $500 labor.
bklyneg
80% ricer
Post by bklyneg » July 25, 2005
well i hope you checked the head stamp because the early b20b's came with p75 head. as we all know are b18b heads.
