MagillaGorilla wrote:Just for reference the thinner the head gasket the higher the compression, due to the head being closer to the block. So if u get an insane compression just put on a thicker HG, and check the outcome.
Yes, To explain it more. When you put a thinner headgasket on. The cubic centmeters (cc) of the combustion chamber gets smaller(aka head is closer to the the block/piston). Now, this does look good and all and the performance is better, but as your head gets closer to the block, your timing belt gets looser. Now, you will only see a problem when you mill your head a lot, but these are things to think about. Also when you run a milled head and/or a thinner gasket, your valves are now closer to the pistons. With a high lift cams, this can spell danger. a little food for thought.
