service engine light
morecarbonfiberthenu
80% ricer
Post by morecarbonfiberthenu » September 01, 2003
Does anyone know how to turn off a service engine light one yo believe you cured the problem? :ohmy:
Turbogixxer
Post by Turbogixxer » September 02, 2003
It the check engine light (CEL), right? that means that you ECU is seeing that sensor and/or motor is bad and/or not reading right. pull the codes and post them up.
Post by munster » September 03, 2003
Knepper,
It was throwing the CEL with the nitrous, right? Since you have that off now get hold of Don's computer to clear the ECU. See if that helps.
It's shit like this that happens that's making me do an OBD2 to 1 conversion.
80% ricer
Post by morecarbonfiberthenu » September 03, 2003
Not the chjeck engine light, the maintance required. OBDII ULEV isth worst. even w/ the NOS off it still is weird
Ohh. You have a light for the maintenance required thing? What happened to the little green dot that gradually turned red? Don't the new Civics have those?
sleepinonacreeper
80% ricer
Post by sleepinonacreeper » September 03, 2003
let me help. under your dash, there is a button, turn your key until your fuel pump comes on(2nd click) push button. light go bye bye. don't worry it will be back.
80% ricer
Post by morecarbonfiberthenu » September 16, 2003
Thanx for the tips guys, I gt both lights to go out...one wire was cut on my TPS...fixed.
The second like was what boob said but the new switch is the trip reset button.... it's only a like oil chnge light...shit i didn't know i never had an OBDII car b4 this one
