whats the best
tomoyasu
whats the best
Post by tomoyasu » September 24, 2006
swap for a EF for under 1k?
Post by kotomile » September 24, 2006
under 1k....
I think that rules out B series, and especially K.
So, ZC or single VTEC are about your only options, how much does a mini-me swap run altogether?
Post by Sean @ NDF » September 24, 2006
it would have to be something single cam, zc probably
Post by Secret Squirrel » September 24, 2006
dseries
vtecdood
Post by vtecdood » September 24, 2006
dseries suck for the money you will have in it 400 more will get you an LS save your money....
yea but u can blow up the d and not give 2 shits
Post by kotomile » September 25, 2006
vtecdood wrote:dseries suck for the money you will have in it 400 more will get you an LS save your money....
400 more for the motor, then there's mounts, linkage, throttle cable, etc. D series is way cheaper because all you need is the engine.
tomoyasu
Post by tomoyasu » September 25, 2006
i need a new tranny though too, fucking 4 speed.
SingleCamEJ8
Post by SingleCamEJ8 » September 25, 2006
sohc vtec d16y8!!!! under a Grand and can prolly be found at your local import recycle center.
BUILT MOTORSPORTSWEAR
"the USDM kid"
tomoyasu
whats the diff. between a y8 and a a6?
