extended wheel studs install
Hatcher
Post by Hatcher » March 05, 2004
I just bought some extended wheel studs and want to install them. I was told I would need a 32mm axle socket and chisles, will I need anything else? also how long would you say this install takes? any advice for doing the fronts? I dont have rear brakes so the backs shouldnt be hard. I just bought some black volk GR-NRS's so I want to put those bad boy's on. thanks
phan
40% JDM
Post by phan » March 05, 2004
this has nothing to do with your stud topic, but who did you buy the volks from? i traded mine awhile back and from what i understand, the guy i traded with is a real wheel whore. :)
Post by kotomile » March 05, 2004
I've replaced a few wheel studs on several different cars, never had to loosen the axle nut or touch a chisel. I just drive out the old one with a hammer and pull the new one through with a lugnut, simple as that, let us know how it turns out, I may have to do this soon...
Post by munster » March 05, 2004
Just get yourself a B.F.H and beat on the old ones like koto said.
One question...you got extended studs for the rear too?
Hatcher
Post by Hatcher » March 06, 2004
phan wrote:this has nothing to do with your stud topic, but who did you buy the volks from? i traded mine awhile back and from what i understand, the guy i traded with is a real wheel whore. :)
I bought them off of a guy that works at inlinefour. They were on simple green's EG on http://www.tunedhonda.com you can see them
Hatcher
well I'm going to install them tomarow. I'll try to hammer them out, we'll see how it goes. thanks
Post by munster » March 06, 2004
Simple Green is a member here too. *off topic*
Hatcher
how do I get the hub off? do I just pry it off with a screw driver and hammer?
Post by kotomile » March 06, 2004
Don't take it off, just drive the studs out on the car. It's easy.
If you can get the studs out with it on the car that's so damn easy. If you'd take the hub assembly off then you'd have all of the balljoints to contend with, etc. it would move around when you're trying to hit it, etc.
