anyone with fastbrakes upgrades?
problem_si
Post by problem_si » October 03, 2006
I hear good things about fastbrakes, not to mention they're the only company that I know of that offers 11" rotor kits for all 4 corners on the Ef civic. I'll be buying the kit that uses the 4 piston wilwood calipers... :)
My only problem is...that dreaded wheel fitment issue.
Does anyone have this kit on their EF...if so, do you know what the smallest wheel size/offset that you can use is???
If it helps, I plan on using OEM integra 15" mesh wheels for daily driving, and 15" Enkei Rpf-1's for racedays.
Re: anyone with fastbrakes upgrades?
Post by 77 » October 03, 2006
problem_si wrote:I hear good things about fastbrakes, not to mention they're the only company that I know of that offers 11" rotor kits for all 4 corners on the Ef civic. I'll be buying the kit that uses the 4 piston wilwood calipers... :)
Talk to your parts dealer. If they're selling the product, they should be well-versed in the fitment of each item. If they're no help, e-mail the manufacturer of the kit (not Wilwood obviously). I have a 4-piston Wilwood kit from Peak Performance on my car and I had no problems with install and fitment, also running RPF-1s :wink:
problem_si
What application are you using the wilwoods on (car), and what size and offset are your rpf-1's???
View my garage.
Post by Sean @ NDF » October 03, 2006
i want wilwoods =(
no not wills wood you fag - i know someones gonna post some shit like that
SoloTwo
20% ricer
Post by SoloTwo » October 04, 2006
Project Mu 4 me. ;)
1987 AE86 Levin GT-S - D-Drug, Version Select, Origin, RS-Watanabe, TRD, Tokico, Cusco, Trust, TechnoToyTuning, Exedy, Kics, Toda, Spal
problem_si
Post by problem_si » October 05, 2006
ToByTuNeD wrote:View my garage.
Well my car isn't a rps13, so that doesn't help too much.
I was trying to get some non-partisan feedback before I called fastbrakes about the kit.
the 15" rpf1's come in +35mm and +41mm offsets. I know that they fit on the 10.2" rotors I have now. I don't think its a question of rotor size, but more about the caliper sticking out too far.
Post by 77 » October 05, 2006
Well my car isn't a rps13...
Nor mine, RS13, no SR20DET. The calipers are very thin, thinner than oem. What you can do is go to Wilwood's site and they have the caliper dimensions. Make yourself a mock caliper (cut it out of paper) and test it on your vehicle. If you don't yet have the wheels, do a bunch of math to come to the same conclusion.
problem_si
I have yet to find anyone with the calipers on the 11" rotors.
Anywho...how do you like the wilwoods on your nissan?
SoloTwo
20% ricer
Post by SoloTwo » October 05, 2006
They look good...thats all he knows.
