Do I need extended wheel studs or are stock OK?
Extended wheel studs
I will put 5 mm width wheel spacers on my Honda Civic VTi 1996.
*CACKYWHEELS
- Approved Vendor
You don't need new studs until you're at 15MM but most people like to run extended studs or even run spacers with the studs already pressed in that go over your existing ones..
Even when it comes to extended studs you could run OEM Acura TL studs as they are just as long as the ARP studs, but a ton cheaper.. Just in case you wanted to get a quick cheap "fix"
