boosting a h22
boost. na tuning. bolt ons.
kaoticimports
boosting a h22
Post by kaoticimports » May 22, 2005
i was wondering what all i need to boost a h22 with stock internals.like fuel and ignition wise.and wat about a block guard.i'm only gunna run 7psi and 10 at the most.
the 3 most feared words: POWERED BY HONDA
HONDA: Hold On Not Done Accelerating
Hondas are like that old girlfriend thats just always around in case you need some action but you dont stay with her because you think you can do better. but in time you realize she was the best thing you ever had
Post by Sean @ NDF » May 22, 2005
you dont need a block gaurd
kaoticimports
well i want one for extra assurance
Post by kotomile » May 22, 2005
It will do more harm than good.
kotomile wrote:It will do more harm than good.
block gaurds are trash, i run 14 psi on my stock 1.6
Post by munster » May 23, 2005
Fuel = Definitely get a Walbro pump since you're still running the Civic one.
Ignition= stock is fine.
blockguard = No.
kaoticimports
Post by kaoticimports » May 23, 2005
whats the harm of a block guard
Post by Sean @ NDF » May 23, 2005
theres just no need really. There are alot of bad stories about block guards overheating your engine and breaking. But that could be due to improper installation. *shrug* There are extremely high hp cars that run without block guards. imo its not necessary, and not worth the money to due it right. Especially with the low psi you plan on running. Spend the money on a wideband 02 sensor instead.
Post by kotomile » May 24, 2005
werd. Block guards impeed the flow of coolant in the water jackets around the cylinders, not to mention that no two blocks are exactly the same, so block guards tend to shift the liners around and cause the piston rings to load up on one side of the bore. Hope I explained that right, it's difficult to put into words.
Post by munster » May 24, 2005
Just like banzai said, get a wideband and a good person to tune.
What setup are you thinking about? fuel management, etc.
