DC2 FRONT END
third generation integra. [94-01]
spoonmebabe
DC2 FRONT END
Post by spoonmebabe » April 07, 2005
oomuskablindoo Good luck on putting your JDM front on. I am doing the exact same including the mirrors. Are you putting the HID headlights on your car as well? If you are you will need to know that if your car has ABS you might run into problems and might need to do some modification moving the modulator back a little to fit the headlight. Dont quote me on that its something that I was told by someone I buy parts from. Also, you have to relocate your radiator over flow tank or buy the one for the JAP DC2. That is if you can find someone that has it. Also, If you dont already have them, you need the hood latch and cable. I've heard that these parts from a 94 up Accord will work but I haven't tried that out yet either. These are just a few things to look into while doing the work. Again good luck and hope to see pics up soon? Also if anyone else has sources for knick knack stuff I'd like to know. I still need to know a few things to help finish my front end. I still need the hood latch and cable as well and if anyone has tried the recommendation that i mentioned above let me know if it worked or what you did?
Post by tenchu » April 07, 2005
was this meant to be a reply?
spoonmebabe
yeah
pretty much. I thought i clicked post reply. oh wells. I had some stuff to add so read again if you know anything let me know. thanks
Post by Sean @ NDF » April 07, 2005
i dont think i understand
