Intercooler Project.
Post by kotomile » August 18, 2006
^ you'd have the same problem with the IC in the mouth too, only now the bottom of the rad is exposed, whereas before any air that was to get to the rad had to go through the IC first.
Post by munster » August 19, 2006
What about heat soak from the radiator since they're so close?
Post by kotomile » August 19, 2006
hmm, maybe, but anytime the fan is on or the car is moving the air will be going through the ic first.
SingleCamEJ8
Post by SingleCamEJ8 » August 19, 2006
nice :up:
BUILT MOTORSPORTSWEAR
"the USDM kid"
vtecdood
Post by vtecdood » August 20, 2006
d3viant wrote:wouldn't you have a problem with coolant temperatures? I mean the air coming off the back of the intercooler is gonna be relatively hot and the hot air is going to pass through the radiator? I dunno if this means anything just thought i'd point it out so you had an outside opinion.
I know when i went from a 2" thick fmic to my precision 3.5" thick fmic i had trouble with temperatures rising and the intercooler wasnt "stacked" like this setup is, a fluidyne then solved the problem. I think heatsoaking would be an issue as well, but i am curious to see how this setup works. Keep us posted. 8)
Post by BRYCE » August 21, 2006
nah, my roomate has been running this setup all year and no problems what so ever. car still pulls strong after an entire day of kickin the shit outta it.
Post by 77 » August 22, 2006
Bryce,
I like.
Laters,
Eric
Post by kotomile » August 23, 2006
Are you going to get a vented panel between the headlights?
Post by BRYCE » August 24, 2006
yea the GTR grill yea. or leave it empty
Post by Sean @ NDF » August 24, 2006
empty
