carputer installed! 56k kill yourselves.
UnsanePyro
- 100% ricer
memphis240drift
- 50% ricer
memphis240drift
- 50% ricer
memphis240drift wrote:haha HACKER. im not positive, but i think you use the same type of navi software that would come with any nav system you could use on a flipout or regular screen. idk why you'd have to hack the windows at all, if anything i think it would just help better support the software
then whats the point of running windows? and why would you run windows if all you are gonna do is run that music software? i would be watchin pron like all the time and getting in mad accidents
memphis240drift
- 50% ricer
if this has been covered sorry i must have missed it, i can hanlde the tech side of the computer but my question is whit the "kit" that the screen went into? did u custom build it for your car or did u buy a plastiv kit for your car then fit the screen to it? what did u do to mold the screen into the kit ?
thanks
im not a big mac fan but here is where a mac mini would be handy
thanks
I took the RSX Metra aftermarket dash kit and took the LCD apart. I used the front part of the LCD screen and cut the metra dash kit and epoxied them together. Then I bondo'd and sanded and bondo'd and sanded, then painted. It came out pretty good I guess.IN2deep wrote:if this has been covered sorry i must have missed it, i can hanlde the tech side of the computer but my question is whit the "kit" that the screen went into? did u custom build it for your car or did u buy a plastiv kit for your car then fit the screen to it? what did u do to mold the screen into the kit ?
thanks
this is in testing stage, before I disassembled it.
this is once I modded it into the dash kit:
here is what the dash kit looks like before I cut it :
for software, I am using:XP Pro
Roadrunner + LSx skin w/ acura symbol
iGuidance 2.1.3
xport3 (com port sharing program)
daemontools
winamp 2.95
netstumbler
the powersupply sends the PC a 'power button' push signal. It basically shorts the power button for a second, it'd be just like you hitting your PC's power button. The PC itself then decides what to do, based on the settings in Windows/BIOS you set. I have mine setup to hibernate. Basically it saves whats in windows ram, to a file, then shuts off. The whole process takes about 8 seconds power off/on.
for those interested in cost, I have a cost tally going here:
robry wrote:I took the RSX Metra aftermarket dash kit and took the LCD apart. I used the front part of the LCD screen and cut the metra dash kit and epoxied them together. Then I bondo'd and sanded and bondo'd and sanded, then painted. It came out pretty good I guess.IN2deep wrote:if this has been covered sorry i must have missed it, i can hanlde the tech side of the computer but my question is whit the "kit" that the screen went into? did u custom build it for your car or did u buy a plastiv kit for your car then fit the screen to it? what did u do to mold the screen into the kit ?
thanks
this is in testing stage, before I disassembled it.this is once I modded it into the dash kit:
XP Pro
iGuidance 2.1.3
daemontools
winamp 2.95
netstumbler
so are the programs that you have installed there the only programs that windows runs? did you set them to load at startup? did you have to create startup items for them? did you have to tweak the registry?
