1994 red ford lightning(original) 91k orig miles.....MINT shape no rust anywere
vortech v1-s trim
2.95 pulley (13psi)
ported windsor jr heads W/ comp springs
arp bolts and studs throughout
comp blower grind cam h.r
full hyd roller conversion
ford racing 1.6 rockers
hardened pushrods
pro-m mass air conversion(big bucks)
trickflow r intake
edelbrock 70mm t.b
pro-m 80mm mass air meter
power pipe
42lb injectors
t rex inline fuel pump(front tank delete)
msd billet distributor
msd cap and rotor
msd coil
msd 6btm ignition
3 core aluminum radiator
180 t stat
hughes built transmission(3000.00)
deep aluminum hughes pan
front mount trans cooler
hughes race converter(1000.00)
cervinis 3in cowl hood
raceline wheels skinnies up front 10's rear
bfg drag radials
rancho adjustable shocks
rancho traction bars
lowered suspension
svo rear end girdle
auburn pro center
1 3/4 long tube headers'
3inch exhaust w/ dynomax ultraflo welded mufflers
aermotive fuel regulator
ford racing valve covers
10" sub w/ amp and components
sony cd player
boost/vac gaue
fuel press gauge
gauge pillar pod
