not sure what its going to take to move everything over to the new server but i want to make you all aware that the move will be comming probly within a day or 2. not sure if there is going to be any thejdm.com downtime while the move takes place but i imagine so.
with this move means the new v3.0.0 is not far behind!
if you run a website or own webspace i suggest checking out the host in the banner i have listed on the header and footer. amazing customer support. amazing sizes and amazing prices. 99.9% uptime gaurantee as well. along with a ton of other features. check it
FYI the tripple rewards ends tommorrow! then prices will bump up and gb sizes will drop down a bit. if you subscrivbe to the triple rewards before the 31st you get the same rate and same plan for the lifetime you are with that server. so the price and plan is LOCKED it wont go up or down
