please help..
Re: please help..
Post by tenchu » March 24, 2010
For to downpipe? You'd go by the downpipe not the turbo. Don't really got a good answer for that one though, sorry.
Teaks92HB
Re: please help..
Post by Teaks92HB » March 24, 2010
Where the turbo and the manifold meet. The gasket by down pipe is fine.
Re: please help..
Downpipe gasket?
Teaks92HB
Re: please help..
No. The downpipe attaches to the side of turbo. I need the gasket above the turbo but below the manifold.
Re: please help..
My bad dude, for some reason when I posted that 2nd reply, it was only showing the first question, I thought it didn't post my initial reply. Any t3 manifold gasket should do!
Teaks92HB
Re: please help..
All good man, thank you.
Teaks92HB
Re: please help..
Well..didn't get to hook up the dc sport and taake turbo off. The turbo was held to the manifold by one bolt and nut. The noise I heard when driving the other night was the other 3 falling off. Eek! But I did remove oil pan and fix the leak. I found oil in intercooler piping. You think the turbo is going bad or the pcv system isn't operating to good with boost? But she is pushing 4 psi now, down from the 5. So I am gonna get that vacuum manifold, new lines, re wire everything, and I'm looking to get ne intercooler piping and upgrade the turbo. What's a good quality turbo?
Thanks again for your help bro.
Teaks92HB
Re: please help..
http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWAX%3AIT this a good buy over the eagle manifold?
Re: please help..
Post by tenchu » March 25, 2010
How much oil in the intercooler piping? Is it like a minute about, or are they soaked? A little oil is normal, thats why people run catch cans, or air/oil separators, to reduce that.
That fastturbo manifold would work just fine :thumbup:
Basically when looking for turbos, don't get anything off ebay. Garrett makes great turbos in pretty much any size you can dream of. Theres also Precision & Borg Warner, but they are generally only used in fully built, big boost setups. A Garrett T3/TO4E turbo would probably be about perfect with your engine with stock internals. I'd say somewhere around .50 or .60 trim A/R area.
Your next area of concern is going to be that manifold. Its an SSAutoChrome manifold (old ebay special), they have a tendency to crack from holding up the weight of a turbo. If it hasn't cracked yet, and you want to try and extend the life of the manifold instead of replacing it, i'd call around, and see if you can find a shop that will weld some supporting brackets, to help dissipate the weight.
Teaks92HB
Re: please help..
Post by Teaks92HB » March 26, 2010
Well in a drunken stage I bought the golden eagle vacuum manifold. My next purchase will be the Blox manifold, unless that's not a good one in your opinion. I just prefer to go with the log style for accessibility to everything in the motor bay. If you recommend a different one though lemme know. I have a full 2 1/2" exhaust that I need custom fitted, with a Quick Time Exhaust cut out to run open pipe at a flip of a switch. What size down pipe should I look into getting? One that matches the exhaust itself? I couldn't find a name on the turbo but I did see A/R 50 stamped on it. I'm assuming that means something? lol, I'm not sure if it's the size or what.
And I got rid of the shitty altezzas he had on there.. I hate those.. And in doing so I found a lot of bondo :(
I'll keep ya posted..
