Clutch or trans?
Mugen Ferio
Clutch or trans?
Post by Mugen Ferio » May 01, 2005
Today i had to do some running around and when i was leaving Wal-Mart i put the car in reverse and it made a nasty clunk. i knew it didnt sound good but i had to get home so i strated to leave the parking lot and every gear when i would let the clutch out would do the same thing. i was almost home when i was going up a hill in 3rd gear and it felt like it wanted to come out of gear? what would this clunking sound be and why would it the clutch be slipping when at half throttle? any insite would be great.....thanks in advance! oh yeah its a 99 B16B. if it is the trans anyone know how much something like that would cost?
/// MUGEN 無限 Equipped :thumbup:
four.FUNCTION :beer:
JaySmith
30% JDM
Post by JaySmith » May 01, 2005
slipping out of gear is usually the synchros going bad. and by clunking do you me a grinding noise?
Post by .saint » May 01, 2005
i was thinking syncro's as well because mine were going out in my EG when i had it. they usually make a crazy griding noice when u try putting it in gear though. im not sure about the clunk though.
check the motor mounts make sure the motor isnt moving? my buddy's motor was moving and it was making terrible banging noises when he would shift. make sure everything is tight.
Post by munster » May 01, 2005
I don't know exactly what it would be, but I would definitely separate the tranny from the motor and look around. Check the pilot bearing, throwout bearing, etc.
Did you put a new clutch in when you swapped it?
Mugen Ferio
hey john its funny you said that about the mounts......that was the problem...i found the mounting bolt in the road this afternoon when i had to go out again. that is why it felt like the clutch was slipping because the motor was moving and pully the shift linkage. so to answer munsters ? no i didnt replace the clutch but i will be in the very near future. not sure what to go with but i am either getting the Toda or Mugen clutch. just to keep everything the same. i know some are saying its gay but dont be haters :eek: ...haha...peace out 8)
Post by Sean @ NDF » May 01, 2005
cool that you found out what it was. Honda's engine mounts are peices of shit. I suggest Hotchkis now that Place Racing is out of business.
srr makes a real nice motor mount set and so does hasport and jim fab.
as far as clutch. honestly just to brag and say u have a 'toda' or 'mugen' is cool but i wouldnt ball out of control like that i would just go with an act. but thats me.
I can't say anything bad about my ACT clutch and flywheel.
Good thing that it was only the motor mount. :up: Put some poly inserts in dem bitches.
Mugen Ferio
yeah most def about the poly inserts. and after talking with my friend matt he said to go with an ACT.
Post by Sean @ NDF » May 02, 2005
unfortunatly I HAVE heard and experienced bad things with act. My past two clutches have been Clutchmaster's and no problems..yet...
