runing rollcage bars thur rear panels
vtjdmsir
Post by vtjdmsir » August 25, 2006
Im getting ready to build my cage and just wonder if any one has any tips on where to cut my panels to run the down strut bars to my rear wheel well
James Goodyear
thejdm.com / 802 Squad
Post by Sean @ NDF » August 25, 2006
Im not sure I understand the question...
You mean the rear bars of the cage?
Dont Blink
60% ricer
Post by Dont Blink » August 26, 2006
once the main hoop is in just get a shorter bar that will go from the main hope to the plastic and line them up where they will go, if anything this will get you close.
Post by BRYCE » August 28, 2006
cut them where they need to be cut...
vtjdmsir
Post by vtjdmsir » August 30, 2006
BRYCE wrote:cut them where they need to be cut...
thats why im try to figure out where to cut lol
Post by BRYCE » August 31, 2006
well you are the only one that knows what kinda design you are going to do for the cage... so how in a blue moon are we suppost to help you?
Post by Nikku » September 05, 2006
fit the cage, you will see where you need to cut them.
Post by Sean @ NDF » September 05, 2006
i still dont understand this question
spnfedeg6
65% ricer
Post by spnfedeg6 » September 05, 2006
Dude it is going to take alot of panels be put in and out of the car. Making sure your mocking it up exactly where its going to go.... its tough and it takes some time and patience. You may have to get it close and then just open up the holes in the panels. Thats what I did in my car its not perfect but it works. Hope it helps a little.
LiAnn C.
Post by LiAnn C. » November 18, 2006
i took this from a 240 forum.... but this will help you a lot..
tokes¹ wrote:I helped my friend(redSthirteen) install an AutoPower RollBar on his s13 the other day and i took enough pictures to post the install process.
tools:
14mm socket
14mm open wrench
drill (make sure the battery is fully charged!..LoL)
100mm hole saw
jack and jack stand
silicone sealer
install time: id say about 3-5 hours. it took us alil longer because we had to sit around and let the battery charge for the drill.
remove front and rear seats... ImageImage Image now slide the rollbar inside and dry fit it.... ImageImage we had to get alil creative due to lack of tools and use a screwdriver to determine where to drill the hole in the rear panel...LoL Image now drill the holes and install the mounting bolts... Image ImageImage make sure you put some sort of silicone sealer around the bolt holes between the plates to prevent water leakage. ImageImage now put back everything that you removed and youre done!... ImageImage and they said no one could sit in the back.....LoL Image we took it for a test drive and the difference was like night and day.
thats all for now.
watch out for this car when youre out on the backroads..:2f2f: Image
Devious Illusions Myspace :: AIM: XxLiAnnCxX :: LiAnn's Space
1994 Honda Civic Hatchback CX
