come autocross on sun sept 7th in phillipsburg
upcomming shows, races, & events along with thejdm meets.
spun vtec
90% ricer
Post by spun vtec » September 03, 2003
sun sept 7th starts the fall points standings for the central pennsylvania region's SCCA. the race like always is at mid state airport in phillipsburg pa. any info can be found on the local website http://www.scca-cpr.org
you dont need to have a ton done to your car or be an expert driver but let me tell ya its a ton of fun and you wont regret it. directions can be found on the website or mid state airport is usually on any type of map you might have. its good to be there around 9:00 tech is from 9-10:30 and there is a manditory driver's meeting at 10:30(you must attend to drive) car's will hit the track at 11:00 so dont be late you can come to watch also there is no charge. to race if you are an scca member there is a 15$ charge and if your not its only 20$(funds go to buy equipment and such) if you have a good helmet bring it if not there will be loners to use.
come on out and have some fun i hope to see you there.
.:sohc ownz:. > ///M pwr..
Post by munster » September 03, 2003
I always wanted to get into the SCCA. I'll have to meet up with you for one of the races to show me what goes on.
