98 spec b16b shortblock 650plus shipping *freight*
details:intermediate shaft will be sold..the mounts on the block are not there (driverside cast iron bracket/front torque mount/rear tbracket/thermoswitch/flywheel/clutch...if there is anything else missing that i see, will be sure to make note of it, but from a glimpse thats whats missing)
cant really see the b16b, it was so damn cramped when i was trying to take a pic..ill try and get a clear shot of the block ID later
2000 civic front crossmember/subframe with powersteering rack looped, si front sway bar, front lower control arms and forks! wowowowooowow LOL
b series alternator 100mugen thermostat 50-60
SPOON N1 RADIATOR for EK/EG/DC (will most likely fit all 3 but its specifically for EK)
*double pass radiator
*triple core
* -16an bungs welded to the radiator so you can use custom braided lines with fittings or use your stock radiator hoses (they will work)
asking 800
*these pics dont show the fittings welded on themi got tons of vouches via honda-tech 100% feedback via ebay, so you have nothing to worry about!
