|Exterior|
Nighthawk Black Pearl Paint
99-00 Taillights
CTR Style Grille
CTR Style Headlights
Shaved rear wiper, antenna, emblems
|Suspension|
RS`R Japan Springs
Tokico Struts
15" Bronze Konig Heliums
DC Sports Front Upper Strut Bar
|Interior|
00' SI Gauge Cluster
Autometer Gauge Cluster Bezel
Spoon Titanium Shift Knob (Replica)
Clarion 5 1/4 Speakers
CF Gauge Overlay
Autometer Ultra Lite (Silver)
EGT Gauge, Water Temp, Oil Pressure, A/F, Boost
Apex AVC-R Boost Controller
Apex V-AFC Vtec Controller
HKS Turbo Timer
|Engine|
96' B18C1
Y80 Tranny
ACT 6 Puck Clutch
B16A2 Flywheel
Block Bored & Honed to 1.851 (.020 over [81.5mm])
JE 9:1 Forged Pistons with JE Pro Seal Piston Rings
Eagle Forged Rods
ACL Rod Bearings
Port & Polished Head W/3 Angle Vavle Job
Skunk2 Titanium Retainers & Valve Springs
AEM Oil Cap
AEBS Head Stud & Head Bolts
Golden Eagle Cam Plugs
SCE Copper Head Gasket
SCE Copper Exhaust Gasket
Felpro Intake Gasket
MSD SCI Ignition, Plug Wires, Distributor Cap, Blaster Coil
Skunk2 Intake Manifold
Turbonetics T3/TO4E Turbo
MPRD Equal Length Tubular Manifold, Hot Jet Coated
Drag Downpipe Flange
Spearco FMIC
Deltagate Wastegate
Custom 3 Inch Dowpipe w/Apexi Turbo Muffler
Skunk2 Cam Gears
HKS SSQV Blow Off Valve
DSM 450CC Injectors
AEM Fuel Rail
B&M Fuel Pressure Regulator
B&M Fuel Pressure Gauge
Drag Intake Pipe & Filter
99-00 SI Rear Engine Mount
New OEM Timing Belt, Oil Pan Gasket, Valve Cover Gasket
Walbro 255LPH Fuel Pump
Chipped P28 ECU
Hasport Adjustable Shift Linkage
Skunk2 OB2-OBD1 Jumper Harness
These are the only pictures I have of the car. They are about a year old. I will try to get new pictures in asap.
This is with the t3/to4b turbo. It now has the t3/to4e turbo (bigger, more power, better compression)
