Running the DA @ Englishtown
track & strip times. dyno results. race, drift & gymkhana talk.
DA 9_Chinga
Post by DA 9_Chinga » April 04, 2005
So Sat im going to run the DA and was wondering what kind of prep. i should do to get ready for it. Any tips fill me in.
~Chinga
Bennett @ ESG
Post by Bennett @ ESG » April 04, 2005
gut your interior.
I Dream I Drive:... i logged off mycomputer somehow when i typed LOL
Post by .saint » April 04, 2005
dont miss shift. :P
civicex2g
85% JDM
Post by civicex2g » May 10, 2005
make sure you have battery tie downs.. no cracks in front windshield... just basic stuff like that soyou can pass tech (atleast thats how it is down here at moroso)
Post by Sean @ NDF » May 10, 2005
air your front tires way down, take out what you can from inside, dont fuck up shifting and most of all...HAVE FUN! it's a blast your first time. Oh yea, dont go into the water either, you dont need to do a burn out unless your running slick, it will only hinder your traction even more
TRAVASS
10% JDM
Post by TRAVASS » May 10, 2005
1. some places require helmets.
2. 1/4 tank of gas is good enough.
3. know how to stage before you get up to the freakin lights, so you dont waste your time and everyone elses by red-lighting!
you shouldn't need a helmet unless you run under 12
Post by kotomile » May 10, 2005
Air your rear tires up, less rolling resistance.
jdmgSix
Post by jdmgSix » June 15, 2005
what about launching what rpm would be good. from what I know your supposed to rev it up to the point to where ur cams kick in. sorry i dont really drag
89 was a good year.
...Lovin the Si
Post by kotomile » June 15, 2005
the cams are always "kicked in" :P You mean VTEC?
Launch rpm is something you have to play with out on the track, you must find the sweet spot where you don't bog and fall under your powerband but you don't want to spin either. It's different for every car/driver/tires/clutch/flywheel/etc. There are too many variables to give an rpm over the net.
