may have found an EG
tomoyasu
Post by tomoyasu » August 19, 2007
but i need to know what the cost is for replacing a rod bearing? anyone know?
Post by boostjunkie95 » August 19, 2007
Alot if your planning on having someone do it. Chances are the crank journal is beat up from the bad bearing. Your prolly better off buying a running short block and dropping it in.
mcmBuilt
Post by mcmBuilt » August 19, 2007
boostjunkie95 wrote:Alot if your planning on having someone do it. Chances are the crank journal is beat up from the bad bearing. Your prolly better off buying a running short block and dropping it in.
Exactly....Had to do it for my daily. I pulled a short block at a junk yard for $110.
tomoyasu
if thats the case, i'll look for something else. i plan a doing a swap so there would be no point in buying another stock engine and i wont have money for the swap right way either
.rob
Post by .rob » August 19, 2007
get a dirt cheap eg.
gut everything out. leave one drivers seat in. get a bride.
roll cage. paint. basic automodellista shit. you're good to go.
tomoyasu
naw, gotta have 2 seats ;) and something that will run good enough until i can afford a swap. but thats bassically what im going for
Post by hondalowlow » August 20, 2007
get a used d15b7 there like a 100.00 at a junkyard case of beer and swap that fucker.
tomoyasu
Post by tomoyasu » August 22, 2007
found a different one...actually i found it a while ago, but thought it would be sold by now. hell of a good deal too, 92 hatch, new b18c5 with 5000 miles, clean body and interior too. he wanted $5500 a month ago...
tomoyasu
Post by tomoyasu » August 23, 2007
that other one that needed a rod bearing now says it comes with a complete short block.....not sure of what engine though..its an si too...
.rob
Post by .rob » August 24, 2007
but you have no greenbacks.
