Its about damn time!
- SingleCamEJ8
project fo sho!!!munster wrote:Good stuff, man.Are you turning it into a project or are you just going to beat it and have fun?
the tranny is from ls model i believe. is there anyway i can get the hood oopen without swapping the cable first? naw th HVAC is cracked at all, he also gave me a spare one too that looks to be from an siNikku wrote:there is a lot wrong with it. fix it. changing out that tranny will make the car sooooooo much faster, unless the DA tranny is from a B17a. the windows will not be so fun to fix. To fix the problem with the hood latch, just swap out the cable. while you are at it, route the cable thru the engine bay. the hvac controls are pretty much a given that they will be messed up on an ef. are they cracked?
yeah, change that tranny out quick. having an LS tranny on a B16 really really makes the car slower, the gearing is way wrong. although finding a cable b16 tranny isnt an easy task either. as for opening the hood, if you can fit your hands into the engine bay thru the front bumper you can pop the latch that way, or, if you reach into the driver side wheel well you should find the cable, pulling on that should pop the hood. if the HVAC isnt cracked then there are couple things that could be wrong with it. either the cables snapped, too much slack in the cables that run to the vent switcher thingy (technial term
), or the cables arent hooked up right. swapping that thing out without cracking the place where the cables go is really really really hard haha.
nice project ya got there
