looking to do an engine swap??
theindulger
- 100% ricer
looking for b16 engines to put in to my 1998 honda hatchback but having a hard time find one
http://www.HMOTORSONLINE.com ...u can get your motor there
I highly recommend hmotorsportsonline.com. However, if you should go else where I would advise you to stay away from private sellars as much as possible, unless you legitmately know the source. Also, avoid buying any motor older than 1992. 90% of the time you be dealing with faulty FITV, EACVs, and ECUs - they are not pretty to mess with.
Another advice, make sure you have at least $1500 on the side for tunes ups and upgrades, such as timing belt, head gasket, alternator belts, etc....
