Auto to manuel conversion
Beatfiend
90% ricer
Post by Beatfiend » March 22, 2005
lol ok
Beatfiend
90% ricer
Post by Beatfiend » March 24, 2005
well i found some one to help me witht he auto-manel swap so im all w00t w00t, WHHHHHHOOOOOOOWWWWWAAATTT, OOOOOOKKKKKKKAAAAAAYYYYY right =]
Beatfiend
90% ricer
Post by Beatfiend » March 26, 2005
yeah im sure it will the sweetest thing ever!!! if anyone checked out the march sports compact the with rhd crx thats the guy that hopefully will be helping me out
h0merow
if you need some tech help
Post by h0merow » May 06, 2005
I have also done a auto to manual in an eg. its not really all that hard. but the biggest thing is that depending on the car. 92-95 civic for example. you will have to change the passegner side bracket on the frame rail because the one for the auto tranny is back 1.5 inchs and tilted up at an angle. other than that its just a little bit of bull shit wiring so that your car will start and so that your ignition will release the key. As far as linkage is conserned you will have to basically get the tranny in . and then bolt the linkage to the tranny and push it up thru the hole in the floor where you removed the old auto shifter. and drill two holes int he floor to attach the stablizer side of the linkage. then weld some kind of plate back over top. If you need any help hit me up.
Beatfiend
90% ricer
Post by Beatfiend » July 24, 2005
well guys I did and i dropped in this
Image i wanted to give a big thanx to JOE cho and Randy Gagan for the Big help thanx
ls.pwrd.hb.
75% JDM
Post by ls.pwrd.hb. » July 24, 2005
looks good as hell man
low n slow
Beatfiend
90% ricer
Post by Beatfiend » July 25, 2005
thnx got the apexi 4-1 headers upgraded cams, mugen valve cover as u can see project phill is at 30% right now this week i pick up the rest of the sir interior and hope fully the SIR wing
