I would try to soak as much up as possible with a clean rag. Otherwise you have to burn it I guess. I would get new wires just because. When was the last time you bought new ones?
Did you use hondabond or anything on the new O-rings?
Built Motorsportswear - Function/Form Autolife - ICB Motorsports Go Autoworks - K-Tuned - My friends
that happend to my red dragon just on the first cylinder. My plug wire got soaked with oil the whole way to the distributor. I just replaced everything and burned the oil out cuz it burns oil anyways but its fine now.
1996 VSM Civic Dx Hatch - Sold
1990 Crx Si - Sold
1994 Accord ex DD
the last time I got wires was about 15k-20k miles ago...NGK blues
I didn't use hondabond on the new ones yet
*my main question is - if I can't get around to getting this done tomorrow, the oil shouldn't leak into the cylinders should it? THe spark plugs should hold it in there hopefully, because its a lot of oil
my buddy had this problem on his evo...just replaced everyhting and took off the valve cover and we ran it through a parts washer and everything was gravy
