antenna block off plate?
when u put the blockoff plate on...
pull the antenna out and there is a lil metal clip u will notice with a small spotweld. i used a screwdriver and snapped that spotweld and took the clip off... that will allow you to remove the base around the antenna.... then i was able to slip my entire antenna back into my a-pillar... reception isnt that bad actually.
Good looking out on the tip , Jon...saint wrote:when u put the blockoff plate on...
