H23 Hybrid Build, ITS OFFICIALLL!!!
Bah, fuckin idiot on HT sent the VC to my home address back in rochester even though 2 dif times in our IM i gave him my address at college to send it to.
i guess now i have to come home on friday...
Have spent over 500$ buying shit through people on HT this week and bought through 6 dif people and some how he was the only one to fuck up and was the only one i actually had repeated myself about the address...
OK, im done venting now...
- boostjunkie95
OK, So final Check list for parts to make sure im good for sunday.
Recieved/Have (H22):
Head (Assembled)
Head Gasket Kit/ALL O-rings/ALL Gaskets/Seals etc...
Timing Belt
Water Pump and Pipe
Thermostat housing
Crank Timing Belt Gear
Intake Manifold
Valve Cover
P28 ECU(In Transit/ETA friday)
Header
Spark Plugs Wires
Fluids (oil, rad, assembly lubbbbe, etc.)
Reusing (H23/H22 compatable):
Altenator/bracket
PS/bracket (had to modify to work, stil debating looping lines though)
Distributor
Spark Plugs(just bought them fall 07, NGK Iridiums)
SOOO. come sunday should only need to:
Pull Crank Pulley off
Change out the Water Pump/Crank timing belt gear
Put on head/Torque down
Put on cams/timing belt/set valve lash/timing
Hook everything up and start it up
Anything anyone can think of i might be over looking so i can order it today/tonight ?!? would hate to over look some small stupid thing that prevents this from being done/assembled/running this weekend. Getting the plates put on come the 13th and taking it to get tuned during spring break(week of the 22-29th) maybe throw it on the dyno to and see some numbers
Head (Assembled)
Timing Belt
Water Pump and Pipe
Thermostat housing
Intake Manifold
Valve Cover
Header
Spark Plugs Wires
Altenator/bracket
Distributor
