the new B18A1 Block:
All machine work was done at Laskey
Fully Blueprinted
84.5mm Bore
Benson Sleeved
CP 9 to 1 Pistons
Eagle H Beam Rods
Fluidamper Harmonic Balancer
Micropolished and Balanced Crank
ACL Race Bearings
Moroso Oil Pan
Type R Water Pump
Type R Oil Pump and Pickup
Toda Timing Belt
B&R Block Fittings
b16A2 Head:
Supertech Nitride Coated Flat Faced Valves
Supertech Dual Valve Springs
Supertech Aluminum Retainers
Supertech Keepers
Supertech Bronze Valve Guides
Supertech Valve Seals
Skunk2 Pro1 cams
str/bdl cam gears
port work done by advanced motorwerks
3 angle valve job
resurface and bead blast
edelbrock intake
str 68mm tb
