Help finding a how to!
step by step diy guides.
Jams_ek
Post by Jams_ek » January 05, 2011
ok so I am getting ready to remove my a/c and p/s yes for the reason of room for BOOST! but I cant find a how to or any help so I'm hoping on of my boys here can help me out! thanks Guys!
Re: Help finding a how to!
Post by munster » January 06, 2011
As far as AC...just start unbolting shit. All of the hardlines, etc. PS...just pull the reservoir and related lines. Then find another power rack and get the fitting (rubber line side) from it. Unbolt the hardline on the rack, put the fitting on that matches the other side, put a rubber line looped between the two. Before you connect the one end of the loop move your rack back and forth to move air out. Then clamp the line down. You're done.
Jams_ek
Post by Jams_ek » January 06, 2011
nice thanks munsters but what about the freeon?
Well....hahaha. When I pulled my cousin's AC last winter I kinda just cracked the line and yelled "OH NO! I LOOSENED THE WRONG BOLT!" Then I pulled all of the line out.
Post by .saint » January 07, 2011
when i pulled my AC. my car was in the shop and i had the shop drain it for me then i pulled the AC and sold them it. haha.
AC is simple. BUT you are going to need the non AC duct for your heater core if you plan on still using that...
http://www.hondaautomotiveparts.com/aut ... TER+BLOWER
illustration #7.
also if you plan on plugging the hole for the lines you need this...
http://www.hondaautomotiveparts.com/aut ... y5=GROMMET
illustration #20
Jams_ek
Post by Jams_ek » January 07, 2011
oh nice jon thanks man!
and as for the ps loop check this out... has some ac info as well...
http://thejdm.com/forum/viewtopic.php?f ... 83#p170395
Jams_ek
thanks again homie!
