Need some help with an electrical problem
SleepyCx
Post by SleepyCx » October 07, 2004
Ok i have a huge problem.... My blinkers dont work at all not even in the cluster.. every gage in my cluster does not work Speedo, gas, temp... my hazzards and running lights work.. and the cluster it self lights up... cept for the brake light the blinker arrow's (cept when the hazzards are on) i replaced the blinker switch and it still has the problem.. the only thing i can think of is a loose ground... anybody have any idea's :?:
I thought nitrous was supposed to get you high
93 Pearl White Cx...
Post by .saint » October 08, 2004
fuses? check all your electical fuses under the dash and under the hood. maybe a lose connection? pull the cluster out and make sure all the connections are solid.
i blew my hazard lights once and it was a fuse under the hood.
SleepyCx
Post by SleepyCx » October 09, 2004
all the fuses are good... all of them..
Post by .saint » October 10, 2004
did you pull the cluster and check the connections? also look to see if threre is maybe a wire thats loose or shorting out.
SleepyCx
Post by SleepyCx » October 10, 2004
yea i even did a cluster swap.... so im thinking its a ground... but where are the grounds at in the dash
