i got a y8 v-tec intake manifold.. it has TB and sensors.. i installed it yesterday and fired up the car and it kept going " waaaaa mmppttt waaaaaa mmmppttt" it wold idle from 1,000 rpm to 4 k " explain that one... so i changes the IAC " idle air control valve" and the same thing... i swapped the MAP sensors.. same thing i had to extednt he MAP and TPS sensors wires to make everything reach properly... but after all the changin around no luck the same thing... i was thinking vaccum leak... but al bolts were tight and new gaskets were installed... the car takes off like crazy with the type - r style y8 IM.
but then i put all of my stock stuff back on and it runs fine... what is causing the wierd ield and the spuratick.. up and down...? fill me in...
d16y7 to d16y8 intake manifold swap... big problems
when my car did that i had a hose that wasn't connected. there's gotta be a vaccuum leak somewhere that's causing it, or something ur over looking. my leak was on the back of my IM and i had another one by the tranny but that was an old tube from when my car was auto that went to power the torque converter and it just needed to be plugged.
i remember reading something about the automatic y8 manifolds having some kind of holes(air injection ports) that needed to be plugged/covered/ filled-in/whatever... and if you don't do that, it would cause a rough idle... here are a couple links that might help... if you still need some help just search on honda-tech...
http://honda-tech.com/zerothread?id=1040235
http://honda-tech.com/zerothread?id=877486
hope that helped...
hope that helped...
