HUGE GARAGE SALE
buy. sell. trade. anything car and non-car related.
Forum rules
1. please familiarize yourself with the must read before buy. sell. trade!
2. please use sound judgement when, buying, selling & trading on the forum.
3. remember you are buying, selling & trading at your own risk.
4. to make the experience easier please list ways of contact in your post. name, state, email.
5. please be very descriptive of what you are trying to sell/trade. pictures help a lot.
HUGE GARAGE SALE
Post by munster » January 10, 2005
I'm posting this for a buddy who posted it on another forum. This is a HUGE list.
Here's the link to his post on JDMU. http://www.jdmuniverse.com/forums/showt ... hp?t=33242
these parts are as is, they state used or new. The have a price on them. not final price but your final price better be something really close to that. pics sorry. If u are serious about buying something like having cash in hand please feel free to pm me. I am making room for 05...look's like it's going to be a good year for me.......
• GSR Turbo motor Fully sleeved and built, AEBS Sleeves, Crower rods, Endyn 8.5:1 Rollerwave pistons, all bottom end parts balanced, crank Semi-lightened, Crower Turbo cams, Crower Camgears, Crower/Eibach Valve Springs, 3 angle valve job, Ferrea high tensile 1mm bigger S/S intake valves, Crower stock size S/S exhaust valves, ported, flowed and cc head by Gord Bush Performance, Crower titanium retainers, lighted and balanced rocker arms, APR Head and Main Cap bolts, brand new Type R oil pump (shimmed and ported) , lightened and balance flywheel, ACT Extreme clutch with 6 puck friction disk, custom made aluminium intake manifold, 70 mm STR throttle body, Hondata urethane intake manifold gasket, can supply all specs of motor (bearing clearances, etc.) , new water pump, new Greddy timing belt, all new seals and gaskets. $5800.00
• Complete GSR Swap , built for turbo, JE pistons, Eagle rods, Victor X intake manifold, 62mm Type R throttle body, Block guard, new timing belt, water pump, etc., w/ new clutch (Clutchmaster stage 5) and machined flywheel, 15,000 miles on motor. $3200.00
• B18a Short block built with Eagle rods and Endyn 12: 1 piston’s, shimmed and ported oil pump, block guard. 0 MILES, freshly built $1300.00
• GSR long block with Edlebrock manifold and Hondata gasket, JDM block 50,000 kms $1200.00
• 62-1 Garrett turbo charger Stage III wheel hot , .70 A/R cold .63 A/R hot, 62 hi-fi wheel cold new $750.00
• GT 37 Garrett turbo true GT turbine wheel, .54 A/R cold, 1.12 A/R hot, new $650.00 .70 A/R hot $750
• Microtech stand alone NEVER BEEN USED LT-8s all hardware and software included with laptop cord. NEW $1000.00
• Blitz GTR bar and plate intercooler (BIG) 2 ½” inlet 3” outlet NEW $1100.00
• S2000 gauge cluster used $250.00
• SFP welded Cast manifold and down pipe new $400.00
• 2000 Si computer, stock, used $100.00
• MSD 6AL, new $120.00
• MSD Ignition Coil, E-core, new $100.00
• APEXi VAFC w/bracket used $250.00
• Walboro 255 LPH fuel pump new $90.00
• Hal meter AF30 used $100.00
• B16a/ B18c5 Edlebrock intake Manifold used $250.00
• JDM Type R Throttle Body used $220.00
• 81.5 mm Endyn Mid-Compression pistons non-strutted w/rings B series new $SOLD
• “slightly used”(30 miles) Civic Type R pistons on shot peen LS rods w/ARP rod bolts new $200.00
• Shot peen GSR rods w/ARP rod bolts new $120.00
• Eagle GSR Rods new $270.00
• Crane Stage III B series cams used $400.00
• LS complete short block used $SOLD
• ½ mm bigger High compression REV valves new $200.00
• 440 cc RC engineering injectors used $220.00
• Paxton fuel pressure regulator used $100.00
• Complete NOS kit with new Micro switch and bottle pressure gauge used $250.00
• 2 1/2” test (straight) pipe $50.00
• Turbonetics Deltagate 16lb spring used $60.00
• B16a ARP head studs new $SOLD
• Skunk II stage I regrind cams for B16a used $250.00
• 20x14x6 slicks on 14” steelies w/ 4x100 bolt pattern used $220.00
• 22x15x8 slicks on new Rota Slipstreams (white) rims new $400.00
• Crane Digital Hi-6 used $SOLD
• SS Blaster Coil used $SOLD
• Greddy Profec B boost controller used $SOLD
• S2000 master brake cylinder and booster used $150.00
• Eagle LS rods new $320.00
• 60mm SOHC (1st gen B16a) throttle body $120.00
• CRX/Civic MOMO steering hub $50.00
• AEM cold air intake for GSR with “safety” valve (minus filter) $80.00
• Celica intercooler used $50.00
• Neuspeed VW intake guard plating used $50.00
• MR2 440cc injectors used $100.00
• 1988 CRX/Civic Honda Friction disc new $50.00
• GSR stock Camshafts $50.00
• B&M super oil cooler new $100.00
• MR2 Cusco rear strut bar used $50.00
• GSR throttle body used $80.00
• Autometer oil pressure gauge, electric new $50.00
• Autometer Pyrometer new $120.00
• Injen intake for 2000-2004 Acura TL used $100.00
• Tanabe springs for 2000-2004 Acura TL used $100.00
• 6” HKS mushroom used $80.00
• 10” HKS mushroom new $150.00
• Stock LS rods and pistons used $20.00
• PR3 OBD 1 Computer from 93 Integra XSi (rare) used $120.00
• Aeromotive Fuel Pressure Regulator new $100.00
• Wilwood 13.1” big break kit with 4 pot machined callipers (need replacements, Civic, Integra) used $1200.00
:up: Great seller. I bought my seats from this guy. Great to deal with.
Post by .saint » January 10, 2005
:bump: for monky.
