Clutch Help... slipping
Post by BRYCE » February 21, 2005
So last night i was turnin down the street from my house, and bam all of a sudden my clutch pedal is super easy to put to the floor, but still springs back when let off it though. The engine will rev normal but i will hardly move it seem as if the clutch is sliping like crazy! I have to nurse it up to like 45 and i cant apply and throttle without slippin! So my question is, is it the clutch disc its self or what are some possibliltys?? Anyone??
thanks
Post by .saint » February 21, 2005
have you tried to bleed the line?
tommybanzai
25% ricer
Post by tommybanzai » February 21, 2005
sounds like someone better order a new clutch and throw-out bearing
yea but would it go out just all of a sudden??
Turbogixxer
Post by Turbogixxer » February 21, 2005
terror wrote:have you tried to bleed the line?
Listen to him, it is most likely your problem.
yea mabye
jdm delivery
Post by jdm delivery » February 22, 2005
sounds like its going. or just gettin robbed of fluid if its that easy to push in try checking the fluid and as john said bleed the line. if thats not the probelem pull the trans out and check the clutch plate and see if it has any bad scoring or wierd looking scrapes and look how close it is to the rivets. it happened to my ecliple i almost lost hte damn trans
Hercules
Post by Hercules » February 22, 2005
i wouldnt think you need to bleed the line but you never know, i thought the pressure plate is what made the pedal stiff, and air being in the line gave it play...i'd say the clutch is shittin the bed if it went out all of the sudden, just take it apart and check it out
Post by BRYCE » February 22, 2005
yea i am going to pay some one to fix it.
LS1POWER
Post by LS1POWER » May 05, 2005
i know this is a old post post but .... i feel like putting in my 2 cents.... If the clutch is having trouble holding like that it has nothing to do with the fluid. and yes it is possable to go out all of a sudden like that. I would put my money on the pressure plate spring or a broken plate... that would make it easy to press and not have enough pressure to hold the disc against the flywheel. soo it you still drove it like that your clutch disc will be fried too.
and why did you bring it in .... all ya had to do is buy me a six pack and coulda done it for ya.....how much did you end up paying?
2001 CAMARO Z28
12,96 AT 111 mph..... on street tires
http://www.ls1tech.com
