Mini me
2.SloEK
70% ricer
Mini me
Post by 2.SloEK » April 06, 2005
any one heard of the mini me swap... takina a non vtec block and making it vtec was at my friends shop the other day ne said his friend did it and it kept up with b16 im doing it ill let yall the ow it ends up itll be in a lil wile tho
spun vtec
Post by spun vtec » April 06, 2005
yeah man a "mini me" hybrid is nothing new. it is simply mating a vtec (di6z, di6y) head to a non vtec(d16a, d15b) block. Every thing is pretty much straight forward except in the case of the d15b if you dont already have a mpfi swap. only thing you have to remember is to take the cap out of the oil jet between cylinders 2&3... and the dizzy will have to be modified unless you are going obd1(the way i went and would highly recommend it).
Tons of other info for the swap found here:
http://honda-tech.com/zerothread?id=554053 expecially d15b
hope this helps.
other helpfull links:
http://www.honda-tech.com/zerothread?id=735196
http://www.jdmuniverse.com/forums/showt ... hp?t=32971
spun
.:sohc ownz:. > ///M pwr..
Post by Sean @ NDF » April 06, 2005
biggity bam spun vtecs the man
:up:
mini me's are tight if your a one cam man
