EF noob
EF noob
Hello everybody.
Just joined the site, but familar w/ it for some time, so finally came aboard.
Gotta a 91 EF CRX HF I'm working on as a LARGE project. Pretty much a complete redo.
Been around Honda's for some time, now...this is my 4th and final Honda project. It's gonna be a legend someday ... well in my mind at least.LOL
Never did a "JDM" project before though, so helpa a nigga out, ok?
My car is cleaner than your ass.
I actually do not right now.
I wish I took some pix before I tore it apart.
I'm gonna get some prob this weekend, but its not much to see, other then a shell. It has nothing but brake lines and master cylinder in the engine compartment along with the front suspension that i reinstalled already, which was completely redone/replaced/repainted.
The interior is gone completely except for the wiring harness, which has to come out yet.
It's getting stripped to bare metal and repainted the end of this month: exterior, interior, engine compartment, underside.
I wanna shoot some pix before it goes in and the present new front suspension, along with the install of the new rear disc conversion and rear suspension.
- ls.pwrd.hb.
- 75% JDM
I replaced all the ball joints and wheel bearings on the car, I swapped rear discs from an ls Integra in the rear. Front and rear camber kits, A full enregy suspension bushing kit, plus the rear trailing arm bushings in the rear (whatta bitch to install). I did tokicos all around with skunk2 coilovers, new Si front hubs and Skunk2 extended wheel studs. Sanded and scaled all the rust off and repainted flat black, or duplicolor metal finish. I still need to install the rear setup and I am waiting for a set of Function7 LCA's to arrive to complete it. I'm gonna finish the front off w/ a jimfab crossmember/ traction bar. 4 new calipers, Slotted/drilled rotors on all corners, axxis metal pads and braided lines are next on the project to be able to put wheels on it and trailer it to get painted. Hope this answers your question in detail. lol
welcome!
