Car won't start
akhlaq768
Car won't start
Post by akhlaq768 » August 30, 2005
Each time I start the car, I turn the key and the car won't start. You can hear that its trying to start but it doesn't. The brightness of the lights on the dashboard starts to fade, but after a couple of seconds it would start.
My first thoughts would be that the battery may need replacing - but I got that changed a couple of months ago.
The car is a Civic Coupe (1997) and has an alarm and immobilizor.
The following things I have checked or replaced.
Spark plugs (replaced)
Fuel filter (replaced)
Battery (replaced and hold charge)
No engine check light on
Engine oil (replaced)
I was told by a mate, if the car wont start again. Place the jump leads to the battery and the engine (for an Earth connection)
This time when I turned the key the car started. Was that due to the earth connection or luck.
What could be the problem?
Please help.
Post by tenchu » August 30, 2005
Try it a couple times, if it continually works, you probobly have a bad ground, maybe try replacing your ground wire, or terminal connector, you could also just try cleaning your ground terminal connector, that could be affecting the ground if it has a decent ammount of corrosion on it. Good luck!
Post by Sean @ NDF » August 30, 2005
alternator? :(
Post by Secret Squirrel » August 30, 2005
yea alternator came to mind too...but ground sounds more plausable
ls.pwrd.hb.
75% JDM
Post by ls.pwrd.hb. » August 30, 2005
Secret squirrel wrote:yea alternator came to mind too...but ground sounds more plausable
low n slow
Yeah I figured alt. untill I read his thing about earth ground.
Post by Sean @ NDF » August 31, 2005
i didn't really read the post :oops: sowwy
Post by hondalowlow » August 31, 2005
check your grounds and add bigger ones or more.
akhlaq768
Post by akhlaq768 » September 01, 2005
The alternator and battery have been checked and they are fine.
What am I looking at when checking the Earth leads????
How much are there meant to be? I can only located 2 leads one coming of the battery terminal to the car and the other from engine to the car
kidkombo
Post by kidkombo » November 29, 2005
check the ground on the thermostat..that killed my car after putting my head back on with my friends..
RIP JOSELITO LITO BARBER HPL 4 life homie
[team2tO][TRIKspeed][EKsquad][fusionX]
email [email protected]
aim twOtoEdEK
smokey 2.0L[/b]
