make 5 lug?
ner0x
make 5 lug?
Post by ner0x » November 04, 2005
well a friend was telling me.
a cheap easy way to put 5lug on your civic/integra is by using the whole
front crv assembly. arms, rotors and, calipers. since the axles are 36mm, you can't use them on usdm cars so you can use axles from a prelude, which bolt up perfectly to a b series motor.
thats your front assembly.
for the back...
using the rear prelude assembly and hubs, and transfer it over to your civic/integra arms.
i haven't actually seen this being done. but thats like 500 bux worth of parts for a 5lug assembly, has anyone heard or tried this before?
i need more information, i might start this project.
..living life on the edge..
Post by kotomile » November 04, 2005
(thinks back to Honda days)
It seems a little fishy to me, some of the things in this mish-mash of parts. First, wouldn't CRV hubs have the same splines as other d/b-series hubs? Wouldn't H-series axles not fit in a CRV hub? And lastly, aren't Preludes 4x1.25?
ner0x
well they are the same spindles, but there 36mm... not 32mm for usdm cars?
and the h series axles is for the rear assembly. using the hub/disc/ect... with the civic arms
98BomexCiv
75% ricer
Post by 98BomexCiv » November 05, 2005
hmm thats a good ?, I really never ever thought of that... :?
Post by .saint » November 05, 2005
if u try it make sure u get back to us on this. thats a good question.
ner0x
Post by ner0x » November 05, 2005
i will
just need more info before i buy the partss :)
